accord 2000 4cyl. outer cv joint boot replacement
Old May 16, 2018 | 01:45 AM
Eran Teitelbaum's Avatar
Default accord 2000 4cyl. outer cv joint boot replacement
hello
i need to replace the outer cv joint boot.
in Haynes it says that the outer cv joint can't be removed from the shaft, so you have to remove first the inner joint. but the parts catalogue indicates there is an outer cv joint as a spare part.
so what's the truth?
Old May 16, 2018 | 12:00 PM
The Toecutter's Avatar
Originally Posted by Eran Teitelbaum
hello
If the boot has a split in it, and is leaking grease out of it, I'd replace the entire drive axle. I only say that, as you'd have to really clean the hell out of the the CV joint and it's assorted parts, not to mention having to knock off the inner CV joint first. Then there's regreasing of the CV joint with CV joint grease (a moly blend) that really gets into your pores. It's really a dirty nasty job, and just replacing the axle is quicker and easier.
Someone on here posted a link to some good quality aftermarket axles. Maybe they'll post it again for you.
Old May 16, 2018 | 02:09 PM
I've replaced a lot of those boots on VWs & Saabs. For some reason with Honda it's almost less expensive to replace the axle where some other cars its very expensive to replace the axle.
Old May 17, 2018 | 09:36 AM
Replacing a CV boot is easily the messiest job I have ever undertaken. All for naught as wear from loss of grease damaged the parts. My first and last CV boot replacement.
A new axles is < $100 and easy to install.
Old May 17, 2018 | 04:10 PM
a new axle isn't relevant for me.
i've seen here those axles that sell for $69 etc.
i guess you can't get anything more than crap for this price.
anyhow i'm from israel so sending them over here will cost 3 times more, and a new axle at the local dealer is about $900.
Old May 17, 2018 | 05:10 PM
Wow, even the Saab axles aren't that much. That certainly changes the economic decision.
I'd forgotten that you're in Israel.
Old May 17, 2018 | 05:19 PM
Here's the parts drawing. Looks like you CAN remove the outer CV joint.
I guess the retaining clip #13 might be accessible by flexing the CV joint way over. Then remove the axle from the spider of the outboard joint.
#3 is the boot-kit, about $28 here in USA. But the whole axle is about $400 from a dealer here...
Someone already warned you that if the boot is already torn, the joint might already be damaged by dirt getting in there. Like I said, I've replaced those boots, but they were only beginning to get surface cracks & nothing actually was split open. It's a very messy job.
Attached Thumbnails accord 2000 4cyl. outer cv joint boot replacement-2000-4cyl-axles.gif
Old May 17, 2018 | 09:14 PM
i found an online manual that someone linked in this site where they show it can be removed with a sliding hammer.
Old May 18, 2018 | 06:08 AM
OK then I guess the clip #13 just snaps into an internal groove? That sounds similar to how the inboard end of the shaft unsnaps.
I recall threads where people didn't get the driveshaft fully snapped into the transmission, and after a few days it works its way out. So when you put it back together make sure it snaps fully into place (inboard and outboard).
jerrym
Dec 27, 2014 10:43 PM
curvenut
Jan 24, 2013 12:14 PM
DanielC.Young
Aug 6, 2012 04:18 PM
bamaccord
May 22, 2009 03:41 PM
Hoang_Nguyen
May 13, 2007 10:13 AM
