Accord 2007 Vibration
Old Jul 9, 2012 | 11:03 AM
germike's Avatar
Sorry guys for the late reply, was planning to clean the whole throttle body during the weekend but the weather was not that nice to do it
I did the idle learning but the car still the same, no changes
Redbull, i think i have
the rotary air control valve as i can see 2 small water hoses going there and no cover like the 2007 photo you posted
Old Jul 20, 2012 | 04:55 AM
germike's Avatar
Finally i cleaned the throttle body, replaced air filter and injectors as well
the RPM stopped going down that much but still the vibration is there and i found that i have the one with cover as the 2007 photo posted by Redbull
any idea what can i do more, do i have to do the idle learning again?
Old Jul 23, 2012 | 07:56 AM
I guess after cleaning out the TB & IACV; I'd repeat the idle-learning process.
Old Jul 24, 2012 | 08:22 AM
germike's Avatar
i did the learning process but all still the same
any idea how to reset the ECM away from using the HDS as Honda mentioned
i think disconnecting the battery for 5 minutes is not resetting the ECM
Old Jul 24, 2012 | 09:05 AM
I don't know how to reset it without HDS. I only know that beginning in 2003 they used non-volatile memory so you can't reset by pulling the battery cables.
Old Sep 1, 2012 | 07:39 AM
Scar_cle's Avatar
I had some good luck changing the kind of gas i was using. Honda recommends top tier gas only for there cars, and what i was using (BP) is not a top tier. I switched to shell gas and put in a bottle of techron and it worked great, now even with the AC on, its quiet with no vibration. Cant say this will work for everyone, but i needed somewhere to start given that the stealership told me my mounts were all fine.
Old Sep 25, 2012 | 12:21 PM
  #17
germike's Avatar
Unhappy
actually we dont have BP or Shell here, its all local companies
i got my EGR cleaned and did a reset with the HDS and unfortunately all the same
did a check for vacuum leak also and all are ok
i will try to find a good HDS to buy for my self and will compare all sensors values with the service manual maybe i can get any difference some where
sacrider
Jul 9, 2014 03:29 PM
dmullen
Dec 1, 2007 11:28 AM
jwelsch
Feb 12, 2007 04:37 PM
Muffin
Jan 13, 2007 11:01 PM
rottevnm
Aug 17, 2006 09:59 PM
