Accord 94 acting Up
Old Jul 20, 2011 | 08:39 PM
kennilope's Avatar
Default Accord 94 acting Up
Here are the problems:
Car oil indicator will bring after around 30-40 minutes of driving. This happen after a long ride to work.
Second is that the car seem to be accelerating very slow but once pick up on highway at 50MPH it will go smooth.
Car will suddenly will stall at a traffic light or when use AC for a long time. It is jerking when stop at red light..... but it will come back alive if put some gas or when accelerate.
Car will run fine on highway..in city if car is drive for awhile it will stall and die.
I changed Spark plug, Cap and also changing distributor O-Ring.
EGR port was clean last year. I also just replaced the fuel injector O-Rings and clean the juel injector.
I wonder what else is the problem?
Could it be a bad EGR Valve that is causing the problem?
it seem like I have a vacuum leak somewhere..
Still don't know why the oil indicator will blink after 30 minutes driving.
thank you
Honda Accord ex 94.
Old Jul 21, 2011 | 05:31 PM
4 cyl, right? Check/clean the IAC.
When you say egr port-was this the valve or the chamber.
Check the oil level, of course you knew that. Then check the switch and connection.
Old Jul 25, 2011 | 08:31 AM
kennilope's Avatar
can a dirty or bad fuel injector give you loss of power?
Old Jul 25, 2011 | 07:06 PM
Yes it could??? A pressure tester will answer that. So will a vac leak and a few other things.
nubuck83
Sep 3, 2009 09:46 AM
Drkmstr104
Aug 26, 2009 03:59 AM
RTM1216
May 30, 2009 03:20 AM
Andyf
Oct 28, 2007 05:04 PM
drummer1279
Aug 18, 2006 12:21 AM
