adjusting hand brake
Old Oct 21, 2009 | 06:08 PM
aborbonio's Avatar
Default adjusting hand brake
i got a 1994 honda accord manual tranny and my hand brake doesnt really hold i want to know how i could adjust it so it could hold..
Old Oct 21, 2009 | 07:08 PM
You can download a 94 shop manual from spoonertuner link in the Online Manuals thread in the DIY section that will have the exact procedure.
From memory, you jack up the back of the car and put it on jack stands.. Pull the e-brake up for 1 click. Tighten the cable under the center console until the rear brakes slightly drag.
Old Oct 22, 2009 | 07:10 AM
Have you replaced rear brakes lately? The automatic adjusters might take some time to catch up.
Disk or drum brakes in the rear??
With rear disks, you have to pull the handbrake up & down a zillion times after replacing brakes, so the auto-adjusters catch up. THEN adjust the cable under the console.
Old Oct 22, 2009 | 09:15 AM
deserthonda's Avatar
if it has shoes , you need to adjust the shoes first,,,,,,remove the drums and turn the star adjuster till there is a very slight drag when you spin the drum than back it off 2 clicks,
Once done, count the clicks on the hand brake when pulled up, should be 5-7,, if more than that adjust the cable nut at back of center console ,, remove the rear ash tray to get access to it
Old Nov 11, 2011 | 04:57 PM
sebastian's Avatar
Hi mate, I solve this problem on my 1997 Accord. The problem is in the fault bearing in rear calipers-In parking brake mechanism pin. I had to make the brass bushings and
now working perfect.
Not hesite to contact me if you have some questions.
Sebastian
Old Nov 11, 2011 | 04:59 PM
sebastian's Avatar
Ehm - I have noticed, that this is the old topic, but hope helps.
Old Nov 13, 2011 | 09:06 PM
Hey, sometimes new people look through the OLD threads when they try to figure out their problems. Thanks for the help.
turbofrank
Mar 24, 2014 09:29 AM
DannyJdm
Mar 28, 2012 08:03 AM
MessAround
Jan 1, 2012 09:01 AM
RussianBear22
Jun 17, 2007 07:56 AM
98accord98
Sep 8, 2006 01:25 AM
