air conditioner clutch noise
Yes, it's possible. Hard part is getting to the compressor to remove the clutch assy.
You will need to remove PS and alternator, remove 4 bolts that hold compressor to engine bracket. This allows enough space to rotate compressor, access the clutch face and remove the single 6mm? bolt holding the clutch plate. This allow clutch plate to come off. Next, you'll need to use C-clip pliers to remove a C-clip that holds the clutch coil to the compressor. Once this clip is removed, the coil w/ bearing can be removed by tapping on coil w/ rubber hammer.
The bearing can be pressed or driven out. There may be "stakings" that retain the bearing to the coil. They will need to be ground away w/ dremel.
This applies to most Accords. However, you should include your vehicle info in your signature line.
Gooch
Oct 16, 2006 06:01 PM
jeremiah6120
Apr 16, 2006 03:32 AM
