Alternater Problem 94 accord ex
Old Oct 15, 2010 | 06:18 PM
nozz's Avatar
Originally Posted by PAhonda
When you turn the key what happens? Does the starter do its job by spinning the engine? Is the battery fully charged?
You have to provide us with some information, so we can give you suggestions to narrow it down.
"hey thanks" will get back soon. engine does not turn i posted some more info
Old Oct 15, 2010 | 06:21 PM
Edit: Didn't see your last post.
You said that you have an alarm system. Is there a way to reset the alarm? You may be dealing with a bad alarm which can cause starting problems. Not sure if there is a simple way to disable it. You may have to remove the alarm.
The noise may be a different issue. You will have to locate the noise once you get the car started.
Old Oct 15, 2010 | 06:34 PM
Look for an alarm reset button/switch under the driver dash, can be at under dash cover, the hood release area, etc.
While pressing the reset switch, turn the ignition on.
Old Oct 16, 2010 | 05:40 PM
nozz's Avatar
yes bad alarm installation.ripped it all out
car started .noise still there
Old Oct 16, 2010 | 05:55 PM
You will have to locate the source of the noise now that the car is running.
You can use a piece of hose as a mechanic's stethoscope. Be careful not to get the hose caught in the moving parts when the engine is running.
Old Oct 19, 2010 | 02:15 AM
nozz's Avatar
Thumbs up noise
Hey thanks everyone,
so the faulty alarm solved that one. Frikkin awsome.
Now the noise,if anyone can help.sounds like it is comming from
the Alternater or somthing very close to it all the belts & wheels turn.
It's right after start up. it kinda sounds like Herbie when he was lost in the
fog in san Francisco in one of them movies,only louder........
Old Oct 19, 2010 | 11:27 AM
  #17
You can also use a broom handle to hear your parts on your car when it's running or one of those small wooden baseball bats kids use.
I keep one next to my drivers door just for that purpose .... and for other things of course.
Careful so you don't knock your head off when doing it.
Old Oct 21, 2010 | 11:56 PM
  #18
nozz's Avatar
Default Hmmmm!!!!!!!
so i have not figured out the noise yet but, whats your oppinions on
these addatives for the Transmition? Its my girlfriend's car and she wants to
ditch it ,i myself like it , it needs the usuall stuff brakes aligihnment tyres
and i like that v-tech engine 2000 mi . I drive a 98 nissan xe 1000+ mi
self maintained .
Thanks
trouble
Aug 21, 2012 07:46 PM
jkrueger2020
Mar 10, 2011 02:18 AM
kellysa111
May 1, 2009 08:35 AM
mahones
Oct 13, 2008 08:24 AM
92Inspire
Aug 13, 2006 03:37 PM
