Auto transmission
Old Feb 10, 2015 | 10:17 PM
Matthew Andrade's Avatar
Default Auto transmission
Need help so my 98 accord auto trans 4 cylinder won't shift out of park I have to get really rough with the button once out of park it's fine but as soon as I go back to park I have to bang the button a few times to go in to gear
Old Feb 11, 2015 | 09:49 AM
What "button"?
This new-member area is just for general welcome & introductions so I'll move this over to General Tech.
Old Feb 11, 2015 | 09:50 AM
Hello Matt
Thank You for joining the HAf..Ive moved you to the correct forum for your question..Please make sure you follow the posting rules as to where your post's go from now on..
Again Thank You For Joining.
Old Feb 11, 2015 | 09:53 AM
Talking Hey Jim!
Hello Matt
And Thank You Jim for moving to here also. lol
Old Feb 11, 2015 | 06:04 PM
M-train's Avatar
Sounds like you need to take the shifter **** out, and I would bet the plastic, "button" is most likely broken.
Old Feb 12, 2015 | 06:09 PM
Some possible culprits:
• Blown fuse – First check under-hood Fuse no. 47 (20A). Also check driver’s side under-dash Fuse no. 9 (7.5A) – Not likely to be due to blown fuses if there are no other problems ; but, at least check under-hood Fuse no. 47.
• Wiring issue - short or open (break) in wiring
• Brake pedal position switch
• Throttle position sensor - The voltage needs to be at less than .5 volts (this essentially tells the PCM the accelerator pedal is not depressed and the throttle is closed). If it is at a higher voltage, the PCM thinks the accelerator is depressed and the throttle is open and prevents the shift lock solenoid from energizing (you won’t be able to shift out of Park).
You can try unplugging the connector to the TPS, you’ll get a Check Engine Light; but, see if you can shift out of Park.
• PCM (Powertrain Control Module)
• Transmission Range Switch – Is the P light on? Can be faulty even if P light is on.
This is how the shift position interlock works:
When you push the brake pedal, battery voltage is sent through a WHT/BLK wire to the PCM. If, at the same time, you do not push the accelerator pedal, a low voltage signal is sent from the TPS through a RED/BLK wire to the PCM. The PCM then applies voltage through a WHT/RED wire to the shift lock circuit in the driver’s multiplex control unit. When you move the A/T shift lever from the PARK position, ground is provided to the shift lock solenoid. The solenoid is then energized allowing the shift lever to be moved from the PARK position.
Old Feb 12, 2015 | 06:23 PM
There is a shift lock release slot; so, you don't have to force anything when you have a problem.
SwitchUps
Oct 21, 2010 05:37 PM
HondaDad
Jan 29, 2007 01:02 AM
dejavu247
Dec 4, 2006 07:50 PM
AndrewRWC
Aug 31, 2006 10:11 PM
oldaccordowner
Jan 21, 2006 08:31 AM
