big problem
Old Sep 12, 2010 | 03:29 AM
drumminggonzo's Avatar
Default big problem
i have a 91 accord lx 2.2 when i get in the car at a cold start it runs great it idles at about 900 rpm and drives great but after about 3 min the idle goes to about 550 rpm and i have to take off real slow cause ifi put tomuch gas it will stall and on top of that about two to three times a day it wont start for a while ill put the key in and to the on position and the s light will flash i have gotten it to start twice while this happened and it wouldnt go more than 5 miles an hour but luck enough turn it off then back on again and fine still sloppy take off but no flashing s i have been tild main relay but ipulled it and it was good new spark plugs wires timing belt help please im a poor delivery boy in school i can afford the part most likely but not the 100 dollar diagnostic and its to old for the ones at the parts store
Old Sep 12, 2010 | 08:20 AM
Try getting the code from the trans, try searching for the below or in the DIY section of this forum on how to find the connector and shorting it.
techauto "dot" awardspace "dot" com -look under transmission
Old Sep 14, 2010 | 01:08 AM
has nobody heard of a problem like this
Old Sep 14, 2010 | 01:23 AM
I haven't myself and I had a 1991 for 9 years before it got wrecked in a parking lot...
Old Sep 14, 2010 | 02:00 AM
The S light flashing means the transmission computer detected a problem. Follow the instructions on this site. Use a piece of wire or a thin paperclip to short the blue two pin connector behind the passenger side kick panel to get the code(s).
techauto.awardspace.com/transmission.html#troubleshooting
Old Sep 26, 2010 | 10:07 PM
the tranny is fine shifts great no leaks and the problem is the car wont turn onmost of the time it does but on occasion when i put the key in and to the on possition the s light will flash and the car wont start wait about 2 to 5 min it will start no problem by the way it accelerates fine now seems the first mechanic i took it to didnt pit it in time right
Old Sep 27, 2010 | 07:02 AM
It's a little strange situation, so do what PA suggested & read the transmission error codes. Even if you think the transmission is fine. For some reason the trans THINKS it has detected a problem, so you'll help all of us figure this out if you read the error codes.
bdawn8403
Feb 1, 2008 08:03 PM
blackex19
May 1, 2007 03:26 AM
sssexy70
Apr 24, 2007 03:24 PM
BIGGS01ES
Apr 3, 2007 10:06 PM
kramrkixass@yahoo.co
Nov 26, 2005 12:42 PM
