Brake pressure
Old Dec 13, 2011 | 07:50 AM
techjohnny's Avatar
Default Brake pressure
My rotors need to be replaced, so purchased new rotors and an impact screw drivers, but after removing the tire, realized that my break line was leaking, but did not notice a tear or crack in the brake cable, but did notice that one of my brake pads managed to slip out.
Anyways, could not remove the rotors, the job seems to require more than just an impact screw driver, there is also a hub or something covering the rotor.
Finally, after releasing the bleed screw the drum went back in, but still no brake pressure on that side. The brake fluid level is staying steady also, so it can't be a broken or leaking hose?
What is causing no pressure on my brakes, if the brake fluid is steady and not leaking?
The right side seems to be working fine. Also, there is a new clicking noise that wasn't there before.
Thanks,
--tj
Old Dec 13, 2011 | 07:55 AM
Please post these in the Gen Tech section.
eduard
May 9, 2013 12:11 AM
Brad_bibbee
Mar 6, 2013 08:29 AM
piconrule
Jul 24, 2009 02:38 PM
staunch1
Apr 11, 2009 09:32 PM
mamtsberg
May 20, 2007 09:25 AM
