A/C - Not Consistently Cold
Old Jun 17, 2010 | 10:04 AM
19962door's Avatar
Question Air-Blend Door
Originally Posted by PAhonda
See page 21-25 in the 94 shop manual that you can download from the spooner link I posted in the Online Manuals thread in the DIY section.
I found the page you're talking about, which is page 968 in the pdf counter.
However, I'm not sure what the air-blend door looks like, or is that something that's not actually visible?
Thanks,
Robert
Old Jun 17, 2010 | 01:21 PM
kris_loehr's Avatar
The cable adjustment for the water valve cable end which is in the vehicle and the blend door I believe you get from the passenger side after you remove a small cover that snaps on. It is below the center of the dash or the right side of the center console area.
Old Jun 17, 2010 | 06:15 PM
Just found mine, let me see if I can help you with yours. Lower left of the glovebox about where the console (need my kids to teach me the camera and to post pic's) meets the glove box there is a black "cover" with a small window in it where you can actually see some levers and a cable. There is a single "push pin plastic thing" holding the cover. Remove slowly and you should see it. Move the **** from hot to cold to be sure you see movement, if so "you found it". Hope that helps. Thanks to everyone else one mine...
Old Jun 18, 2010 | 03:39 PM
19962door's Avatar
Talking Next Step To Getting Cool Air
Here's what I can report so far:
1) I reached 100,000 miles today! I feel this is a big accomplishment, being this has been a weekend car for many years.
2) Both fans are turning when the A/C is on.
3) I found the box discussed above - I could see the device pivoting when I turned the temperature ****.
4) The A/C was cool - not cold - when I first when out this afternoon. I left the car in the sun for about 1 hour. As usual, the cool air dissappered when I used the A/C again. This has happened for a while now. Usually, the air would become cool after about 1/2 on the road. Now, this doesn't happen.
What is the next step? I would think a pressure test, and replacement of the refrigerant.
Thanks,
Robert
Old Jun 18, 2010 | 03:44 PM
deserthonda's Avatar
it sounds like it is low on freon......,, hook up pressure gauges and report the readings..
Old Jun 18, 2010 | 03:49 PM
19962door's Avatar
Ok, will do. I'll report back as soon as possible, probably Monday.
Thanks again,
Robert
Old Jun 28, 2010 | 10:02 AM
  #17
19962door's Avatar
Talking A/C Working Again
The tech tested the system, and found the pressure was low. No leaks were found.
He recharged the system with R-134A, and now the A/C is working again. This comes just when it's needed, as its' been hot the last couple of days.
Thanks for everybody's help.
Robert
adamc44
Oct 12, 2021 04:27 PM
johnnyg
Dec 27, 2014 03:36 PM
twistofmatt
May 6, 2014 09:19 PM
BHoward711
Apr 12, 2010 08:57 PM
spoconn
Aug 21, 2009 07:06 AM
