A/c water leaking into cabin
Hiya everyone,
New guy here and need some help. My 1996 Accord is getting water from the A/C on the front carpet. Sounds like the drain valves are clogged...my question is where are the valves located and a best method to clear them?
Thanks in advance,
Larry
Thanks in advance,
Larry
This should go in General Tech, so I'll move it.
At the very bottom of the ventilation system, there should be a hose going into the firewall. From underneath the car, it comes out at the bottom of the firewall, maybe hidden by the steering rack. Anyway, squeeze & flex that hose & see if that works the clog free. Be careful it doesn't blurp out onto your face...
If that doesn't work, poke something into that tube, like a weed-trimmer string. That's sorta soft & flexible, better than metal wire which might pierce the hose...
ccasey3655
Jul 7, 2010 08:02 PM
guinnessmike
Jan 20, 2010 11:12 AM
VZ2
Sep 3, 2009 12:25 PM
