A/c water leaking into cabin
Old Jun 20, 2013 | 04:05 PM
larrycrilley's Avatar
Default A/c water leaking into cabin
Hiya everyone,
New guy here and need some help. My 1996 Accord is getting water from the A/C on the front carpet. Sounds like the drain valves are clogged...my question is where are the valves located and a best method to clear them?
Thanks in advance,
Larry
Old Jun 20, 2013 | 04:56 PM
This should go in General Tech, so I'll move it.
At the very bottom of the ventilation system, there should be a hose going into the firewall. From underneath the car, it comes out at the bottom of the firewall, maybe hidden by the steering rack. Anyway, squeeze & flex that hose & see if that works the clog free. Be careful it doesn't blurp out onto your face...
If that doesn't work, poke something into that tube, like a weed-trimmer string. That's sorta soft & flexible, better than metal wire which might pierce the hose...
Old Jun 22, 2013 | 01:54 AM
And welcome to the forums to you also new member.
Old Jun 22, 2013 | 09:43 AM
Another method I've used before. I've used a shop vac on the end of the tube before....be sure you have it set up for water
Again, just another idea. I've used the method Jim described as well.
Jacob305
Jun 6, 2013 12:35 PM
ccasey3655
Jul 7, 2010 08:02 PM
guinnessmike
Jan 20, 2010 11:12 AM
puresoundz
Sep 25, 2009 10:24 AM
VZ2
Sep 3, 2009 12:25 PM
