Can not change where the air blows!
Old 11-16-2014, 04:43 PM
On the heater control panel, the mode buttons are used to select the vents the air flows from (see attached image).
These buttons on the control panel operate a mode control motor to move doors for the air flow. There may be an issue with either the wiring, motor, control linkage, or heater control panel.
Old 11-16-2014, 04:49 PM
See post #25 in this thread for the service manual:
https://www.hondaaccordforum.com/for...ls-4597/page3/
Old 11-17-2014, 09:57 AM
Mike Welker's Avatar
I can not see the link in that post. It's a bunch of gibberish.
Old 11-17-2014, 09:59 AM
Sorry if I'm a pain but i'm mechanically able but not much on diagnosis. I do appreciate the help, patience.
Old 11-17-2014, 10:52 AM
1. Generally, the forum rules don't allow live links; so, that is why the poster altered the web address. Just copy and paste, and then replace the "(dot)" with "."
2. Take a look at the manual and if you still need guidance let us know and I will try to write up some test procedures. A multimeter will help; but, there can be some limited testing even without one, such as connector direct battery power and ground to the motor.
Old 11-30-2014, 07:11 PM
I was finally able to try and work on this problem. I was able to manually assist the motor in switching too the defroster. I believe that it is not in the controls but maybe the motor is getting weak and not able to complete the switch. After i helped it switch I unplugged the motor so it would not be able to switch again. It's a temp fix but not permanent.
  #17
Old 12-01-2014, 11:34 AM
Working that action manually might give you a clue whether...
1. the motor is getting weak like you said.
2. the motor is OK but the linkage & air doors have excessive friction.
  #18
Old 12-04-2014, 07:30 PM
On the 95 EX I had, I would have to re-lube the linkage for the mode control motor every two years or so.
A bit of lube is a pretty easy/cheap try.
I didn't look at the diagrams to compare the difference in the set up between your car and the 5th gen I'm talking about.
emerald
05-25-2020 05:14 PM
4x4aholic
11-03-2013 06:26 AM
dhw682
09-04-2010 06:58 PM
74joe74
07-02-2009 07:26 AM
dragonle87
05-06-2009 06:42 AM
Quick Reply: Can not change where the air blows!
