can't access window regulator removal bolts
Old Feb 19, 2013 | 01:46 PM
fvansan's Avatar
Default can't access window regulator removal bolts
2005 Accord Coupe. Right passenger window is all the way up, not working and the window regulator needs replacement/removal. To access the bolts holding it to the door panel, the window needs to be lowered, but it won't lower due to it is not operating. Any suggestions on how to lower the regulator apparatus to it's bolt removal location in the door panel?
Thanks a lot.
Old Feb 19, 2013 | 02:15 PM
Hamster108's Avatar
cut the metal with a cutoff wheel, mig weld back on.
Old Feb 19, 2013 | 03:42 PM
1. Are you sure that the window regulator doesn't work? Usually on most Hondas, when the power window regulator fails, the window is in the down position, not up.
Did you try applying direct 12 volt power to the regulator motor? To try lowering it, apply power (+) to the #6 terminal and ground (-) to the #3 terminal on the motor plug. Only do so briefly, as to not burn out the motor if it is good.
2. If the motor/regulator really is bad and the window is all the way in the up position, then cut the regulator steel cable and the window will come down. Have someone help hold the glass, as it will no longer be supported. Then remove the two glass mounting bolts from the regulator. (Use masking tape to hold the glass up after the bolts are removed.)
Although not your problem. If the window was in the down position and the glass mounting bolts did not line up with access holes, you could remove the 4 regulator mounting bolts and then move the entire regulator/glass assembly to access the 2 glass mounting bolts.
Last edited by redbull-1; Feb 19, 2013 at 03:59 PM. Reason: Corrected terminal info. for right side motor.
Old Feb 19, 2013 | 03:51 PM
fvansan's Avatar
UPDATE:
During a stop at the post office, I recalled the key fob has a automatic window down feature by holding the door unlock button two times. To my amazement, the right side door window opened. However, now it won't close. The good news is the window regulator functions. The bad news is the window switch assembly has a problem (or so I am guessing so). I am also guessing the problem must be in the right door window switch, but I wonder if the problem is in the driver's master side? Also, how do I close the window What can I do to close the window and how to figure which switch (driver's of right side) is the one needing replacement.
Old Feb 19, 2013 | 03:58 PM
Try applying direct 12 volt power (+) to #3 terminal and ground (-) to #6 terminal on the motor side connector plug. Only do so briefly.
Old Feb 19, 2013 | 04:08 PM
fvansan's Avatar
I got to say, I don't know which ones are#3 and #6. Are you suggesting I run power from my battery + and -? I am sorry to say this is not something I have done before. Which is # 3 & 6? Your help is appreciated.
Old Feb 19, 2013 | 04:21 PM
fvansan's Avatar
Here is a photo of rt side window switch.
ImageShack® - Online Photo and Video Hosting
Old Feb 19, 2013 | 04:36 PM
Apply 12 volt power and ground directly on the motor.
Old Feb 19, 2013 | 08:58 PM
I somehow missed this post of yours.
See attached pic. for numbering of terminal pins. Run power either from your car battery or a 12 volt power source. I use a 12 volt lantern battery for testing.
Attached Thumbnails can't access window regulator removal bolts-regulator-motor-connector.jpg
RaysHondaAccord1994with247.000miles
Mar 15, 2012 01:54 PM
ravenr106
Oct 21, 2011 06:08 AM
ravenr106
Oct 20, 2011 05:32 PM
afisch11
Sep 28, 2011 11:23 AM
Tommy G
Jun 1, 2011 07:04 PM
