check engine light went off
hi to you all, I noticed that the cel light just went off. It has been on since i did some work on the exhaust tube. Is there anyway to replace the bulb or are there fuses that controls the cel. Thanks
Bulb should light when keyswitch is first turned to On position. It could be fuse or bulb, but more likely bulb. If oil pressure, Alt, ABS, etc lights are normal, the fuse is not the problem.
Gauge panel must be removed (see DIY forum) for examples. A shop manual is recommended (Online Manuals post in DIY forum) to guide work.
sc30317
Aug 7, 2012 09:05 AM
tiotico
Jul 31, 2012 08:04 PM
