Climate Control Issues
Hello there.
I have a 99 Honda Accord Ex. Latley the climate control has been playing a game of roullete with me, sometimes it will work, and other times it just won't. When it doesn't work it's usually in the morning and none of the lights will come on. If I turn on the heat, all I get is the fan blowing in the chilly morning air, which doesn't help for defrosting/fogging. The AC is the same. I have noticed that by the end of my work day (4:30) it's back on and ready to go. This is clearly going to be an issue with winter coming up and I'm wanting to fix it quickly. Can anyone tell me what's going on, specifically, or is it a "various things" issue? Someone please help and please elaborate. My car fixing abilities are learned on the fly.
Thank you.
Thank you.
Your problem may not be a loose connection in the back, but in the circuit board of the HVAC panel.
There is a fix where you solder a wire between two points on the board. I'm not sure if the problem is due to simply bad solder or a break in the connection as part of the circuit board.
I posted 2 videos.
Here is a video with someone having issues with their controls. Does your heat/ac look like this?
Here is how to access the panel.
I posted 2 videos.
Hello there.
Thank you.
Thank you.
Does that help to point anyone in the right direction?
I posted 2 videos.
https://www.youtube.com/watch?v=nwicLUwBkPA
https://www.youtube.com/watch?v=v3Sarqc7PpA
I posted 2 videos.
Also, I know I said usually by the end of my work day, they come back on, but they did not yesterday, nor are they on today.
I'd treat them as separate issues right now.
The clock backlight was a common failure on those accords, so you may want to replace the bulb and see if that fixes that issue.
Here is a video on how to replace the bulb. You may want to pick up a bulb from the Honda dealership, or you may be able to find a replacement bulb of the same size from radioshack. Remove the old bulb with filaments, then thread the new bulbs filaments into the plastic base.
greenbean
Sep 21, 2007 03:14 PM
