Cold cranking amps? 07 accord 4 cyl
Old Jul 27, 2013 | 03:18 PM
brian3222's Avatar
Default Cold cranking amps? 07 accord 4 cyl
2007 accord 4 cyl automatic 55 k miles
What is the recommended Cold Cranking amps?
I have been having mysterious starting issues:
every 50 or so starts, turn to crank it--- dash lights all come on like supposed to but nothing when I crank it, flick key back do it again and she cranks and starts. ( all battery terminals and wires have been checked and rechecked for corrosion/loose). The battery checks out as OK with a load test, could it be the cold crank amps are just barely enough? This happens at all temperatures: winter, summer, etc.
Battery:
CCA at O degress: 450 at 32 degees 560 , it's the stock sized battery for the car, new 9 months ago.
Could it be it's just barely enough "oomph" to turn the starter over?
I just can't believe at 55 k miles this car needs a starter.
Old Jul 27, 2013 | 06:46 PM
5.56mm_hickey's Avatar
doesnt sound like a battery issue, starter contacts could be bad.
Old Jul 29, 2013 | 09:11 AM
You checked the battery cables? What about the OTHER END of each of those cables?
opaque
Apr 22, 2013 12:17 AM
5.0stang
Jul 23, 2009 07:24 PM
BlackZ
May 27, 2008 11:43 AM
drewdin
Jul 4, 2007 10:08 PM
