Cooling fan won't turn on!
Old Apr 26, 2013 | 02:47 PM
Time to perform a check of thermoswitch A. Put in boiling water and check contacts are closed. Test is described in shop manual.
If thermoswitch A tests good, then you must have a damaged connector that is somehow not allowing circuit to close despite thermoswitch A being closed.
Old May 1, 2013 | 03:31 PM
Buzo209's Avatar
Alright guys, I replaced thermo switch b, which is the one that's located in the front of the engine by the upper radiator hose and the fans now kick on. But they don't kick on until 3/5's way up on the gauge. I'm assuming its because the duralast switch isn't set to oem temp. When the fan kicks on it only stays on for about 10 seconds then shuts off. Then comes back in in 45 seconds then shuts off after 10 seconds. The gauge never goes past 3/4 mark.
Old May 1, 2013 | 06:10 PM
Thermoswitch B is designed to come on at 225F, even w/ keyswitch OFF. It's supposed to protect against excessive heating when hot engine is stopped abruptly.
Old May 2, 2013 | 12:35 PM
Buzo209's Avatar
So thermo switch B is now functioning but switch A isn't?
Old May 2, 2013 | 04:29 PM
Yes, the jumper test confirmed the wiring is good up to the connector. Either bad connector or switch.
Old May 2, 2013 | 04:58 PM
Buzo209's Avatar
Some one told me about a fan timer module, what's the module designated to do?
Old May 2, 2013 | 09:14 PM
  #17
Module is an electrical bus and contains a timer for thermoswitch B to run 15 mins w/ key off.
Since jumper caused fans to run, there is no problem w/ fan control module. Look at a wiring diagram and this will be clear.
Old May 3, 2013 | 10:05 AM
  #18
Buzo209's Avatar
Possible thermostat not opening at correct temperature?
Old May 3, 2013 | 06:08 PM
  #19
If temp is normal while moving forward at speed, the thermostat is not the problem.
Old May 4, 2013 | 08:37 PM
  #20
Buzo209's Avatar
So it's back to a faulty thermo switch a ?
mega502
Jan 5, 2013 10:08 AM
CDJDM07
Aug 24, 2011 09:51 AM
lordgoose
Jun 22, 2011 10:21 PM
cachinbon
May 12, 2010 06:27 PM
Equalizer
Feb 20, 2007 08:57 PM
