Crank Position sensor help!
Old Feb 22, 2012 | 10:26 PM
argarcia86's Avatar
Default Crank Position sensor help!
Yea im new with repairing 97 honda accord ex, and just need some help on where exactly the crank position sensor is located. I read that its behind the crank pulley, but where exactly, anyone have detailed pics or anything to show me where its at, and where is the tensioner for the timing belt? I took this all apart , and couldnt get the damn top cam back on with the belt.. yes I know im a noob with this, but a fast learner lol! Please help, so I can at least get the car back on the road to drive it to a mechanic.. A guide would be awesome on how to replace this sensor, and im a little slow, so the more detailed the steps the better LOL
THANK YOU!!
1997 Accord 2.2L EX AT
Old Feb 22, 2012 | 10:45 PM
Your best bet would be to go to the ericthecarguy website and under the tools heading, there is a video on 1990-2002 4-cylinder timing belt. It costs $11. He goes through step by step on how to do the timing belt on a 4-cylinder accord. The one in the video has a crank sensor that he removes while doing the timing belt.
Old Feb 22, 2012 | 11:15 PM
These two links show the crank position sensor on the 96-97 Accords.
Honda-Tech - View Single Post - bad crank position sensor??? i need expert help!
Honda-Tech - View Single Post - Crankshaft position sensor???!!??
This next link is a guide on timing belt replacement; however, the Accord shown may be a 94 or 95 ( which had the CPS located in the distributor). However, with the above links, you see where the CPS is located for the 96-97. The engine blocks for the 94-95 are basically the same as the 96-97.
How-To: Replace Timing Belt, Timing Balancer Belt and Water Pump on a F22B1 - Honda-Tech
Old Feb 23, 2012 | 06:49 AM
It's a combined sensor, CKP and TDC. Located just below the crankshaft, fastened to the oilpump housing, shown as #17 in this picture. You have to remove the lower timing cover, which means removing that #^@#& crankshaft pulley.
pondrun
Nov 8, 2021 09:40 AM
Pacman311
Sep 28, 2013 06:26 AM
Tyler Joyce
Sep 24, 2012 08:52 PM
dineromike1
May 26, 2010 10:57 AM
keefer
Jun 16, 2008 08:29 AM
