cruise control issue 96 accord lx
Old Jul 15, 2014 | 09:48 PM
irochaf's Avatar
Default cruise control issue 96 accord lx
cruise would work intermittently and i my speedo was acting crazy. i replaced my vss, repaired my speedo and replaced brake light switch, tested the cruise actuator selenoid. i adjusted the actuator cable as described in the manual. still, sometimes i start the car and the cruise works perfectly and sometimes i start the car and it doesn't. when it doesn't and i try to set it, the cruise light on the dash comes on and turns off. i'm trying to nail this down. what next?
Old Jul 15, 2014 | 10:29 PM
There are several items that can cause the cruise control not to work.
This isn't the most accurate test, but grab the gear selector (is this an automatic transmission accord?) and shake it while in gear. See if the CC works.
Are the brake lights on constantly when the CC stops working?
Do you know how to back-probe an electrical connection and how to set up a volt meter to measure voltage or continuity to ground?
Old Jul 16, 2014 | 07:44 PM
irochaf's Avatar
thanks for replying. i will try the shake test next time it doesn't work and i will check to see if the brake lights are on constantly. i have become familiar with a multimeter. i have used it recently to test an alternator, battery, and the cruise actuator plug for resistance. i replaced the brakelight switch by marking the old one with white out and marking the new one the same. it appears it is making solid contact with the brake pedal. could that need more adjustment?
Old Jul 17, 2014 | 08:36 AM
Problem appears to be a faulty cruise On switch.
This switch should stay in On condition whether cruise is selected or not and remains on when keyswitch is cycled from On/Off/On. If it drops off, the switch is likely faulty.
Old Jul 18, 2014 | 07:54 PM
irochaf's Avatar
if you are talking about the cruise switch on the dash to the left of the steering wheel, i swapped that out and it does stay on. could it be the switch on the steering that you press to engage the cruise?
Old Jul 18, 2014 | 09:05 PM
I didn't understand your post.
Yes, switch on the steering wheel or the cable reel can cause this problem.
Suggest downloading the 94-97 Accord manual from Online Manuals post in DIY forum.
Old Jul 19, 2014 | 11:31 AM
irochaf's Avatar
appreciate your time on the matter. i do have a manual. after fixing all of the things i mentioned, i was just trying to figure out where to go next.
Chedstr
Feb 1, 2013 08:25 PM
dbielawski
Jul 11, 2012 07:31 PM
nickmg555
Apr 29, 2012 05:23 PM
Rokkandy
Sep 2, 2011 03:08 PM
RaVaGe SpEeD
Jun 9, 2010 02:42 PM
