cruise control not happening
Old May 5, 2012 | 08:45 AM
jessecolter's Avatar
Default cruise solved
Thanks for the replies everyone, I did get the small hose off the cruise pump to the right inlet on the intake manifold and the cruise started working again!
Old May 5, 2012 | 09:06 AM
crispin's Avatar
good job!
Old Aug 29, 2014 | 03:06 PM
Default cruise again
ok so yes I had gotten the cruise working again by fixing the hoses.
then it stopped working, I get the light on the switch but nothing on the dash when I hit one of the buttons on the steering wheel. I'm told the voltage is there, I had replaced the brake switch behind the pedal, is there some adjustment there?
Old Aug 30, 2014 | 08:34 AM
Yes, if you had the brake switch replaced you need to be sure it is adjusted properly.
Old Aug 30, 2014 | 03:24 PM
Default brake switch adjustment
Cool, does anyone have a link to how to do that, I thought it was in this thread, something about backing the nut all the way down first..
Old Aug 31, 2014 | 05:15 AM
There are four pins on the brake switch, when the brake is not pressed there should be continuity across two (A and D). If not there, back off the "jam" nut and screw the switch in until there is continuity, tighten jam nut.
Attached Thumbnails cruise control not happening-5th-gen-brake-switch-test.jpg
Old Aug 31, 2014 | 04:46 PM
  #17
Well looks like I've got continuity where I should, the brake lights work, but the cruise does not come on and the shift lock solenoid for this automatic also doesn't move when you hit the brake. Tested solenoid, it's fine. Anything else you would try?
Old Sep 1, 2014 | 08:34 AM
  #18
Wait, when did the shift lock come into the story.....I missed that. Are there any codes from the TCU.
You did test both positions of the brake switch - a brake switch out of adjustment will still work the brake lights but not allow the cruise to work.
Ryan1984
Nov 24, 2011 08:09 AM
russler01
Feb 23, 2008 12:19 PM
aatc20
Sep 25, 2006 04:28 PM
LaminatedKitten
Apr 30, 2006 06:30 PM
wskipper
Nov 19, 2005 03:49 PM
