a/cwont cool at slow speeds
Old Oct 17, 2012 | 11:51 AM
snicrep's Avatar
Default a/cwont cool at slow speeds
My a/c works fine on the highway, but once I get into stop and go traffic, it starts to warm up. Compressor's working and fan is running. Is this a symptom of over charging maybe?
Old Oct 17, 2012 | 06:39 PM
What year accord?
When the engine is running and the a/c is turned on, do both fans on the radiator run? If not, which fan is not running (passenger or driver side?)
Old Oct 17, 2012 | 09:48 PM
snicrep's Avatar
thought i put that in my info.....its a 96 2.7 6 cyl
Old Oct 18, 2012 | 08:33 AM
Dr. Drivability's Avatar
hmmm...sounds like there is more to the story then you are telling us.
Old Oct 18, 2012 | 11:07 AM
snicrep's Avatar
The story is; new compressor and rec/dryer. evac the system. held fine. put in the prescribed amt of freon. Didn't cool real well around town. I made the mistake of adding more freon without gages after the initial ones. On the highway and around town until the car gets warmed up, its cold. But the temp climbs and it cools much less. if i shut off the a/c the temp gage goes back to a normal range.
Both fans working with a/c on. no debris in the radiator or condensor. Washed it out with water. The only thing I can think of is if overcharging can cause this symptom or if the expansion valve can cause this. Thats one thing i didnt change due to its location.
Side note. I tried to put in a signature but for some reason it says im not allowed to enter a signature. Hello. Administrator
Old Oct 18, 2012 | 11:15 AM
if running the a/c makes the car run hot/overheat, you need to address that first. and yes, an overcharge will diminish the cooling capability. start looking at the health of the engine cooling system.
Old Oct 18, 2012 | 11:23 AM
Can't enter a signature?
Your user profile says "user awating email confirmation". I think there's an email with a link for you to reply, then some of that stuff will begin working. You might have to go back & find it. I don't know how to generate a new email, but if you can't find it we can ask the admin.
Old Oct 18, 2012 | 01:57 PM
snicrep's Avatar
I live in an area where its often over 100f with 80% humidity and the temp reads quite cool as long as Im not running a/c. But I gues Ill start with checking out the radiator and thermostat. I need to take it to someone who has a recovery machine so they can remove the freon and recharge it with the exact amt required.
letsclique
Jul 30, 2012 09:32 PM
EXV6NIGHTHAWK
Oct 9, 2010 10:35 PM
00AccordLX5spd
Mar 22, 2007 06:36 PM
sanchezcruz_20
Jan 30, 2007 02:43 PM
terryshaz
Sep 8, 2006 01:29 AM
