D4 light on, no start
Old Aug 11, 2024 | 05:28 PM
  #111
A bad alternator would cause a bunch of other issues, so you can rule it out. If you stop by a parts store, then can test the battery, alternator, and starter.
There is a cable connecting the gear selector inside the car to a switch on the transmission. It is called the A/T range switch. I'd check to see if the range switch is installed properly or if it is loose. If it looks good, then you can adjust the shift cable.
Kind of a detailed procdure to type out, so I'll suggest you get the shop manual for your car. You can get it at automanualsource.com for $22 and dowload it as a pdf. Definintely worth the investment, since your accord had a host of issues to get to this point.
Old Aug 11, 2024 | 05:59 PM
  #112
TrojanFan's Avatar
This?
Old Aug 11, 2024 | 06:02 PM
  #113
TrojanFan's Avatar
Also when I put it in reverse it makes kind of a loud noise. It sounds like it's down inside the shift lever, and it kinda jerks a bit.
Old Aug 11, 2024 | 06:31 PM
  #114
That is the range switch.
You may have to watch the engine/transmission while an assistant puts it into reverse to location the noise and/or excess movement. You could have a bad motor mount that is making a noise when you shift to R.
Old Aug 11, 2024 | 07:04 PM
  #115
TrojanFan's Avatar
This car is driving me crazy. I'll look into that switch. I noticed the bolt for the front motor mount is missing. SMH!!
Old Aug 11, 2024 | 07:05 PM
  #116
TrojanFan's Avatar
Could one or more of the transmission solenoids cause this too?
Old Aug 11, 2024 | 09:58 PM
  #117
Since this car sat for so long and had a lot of items messed up, keep working through the issues that are obvious. I'd expect you to get a code if you had a solenoid problem and don't think this is a solenoid problem. I think the PCM doesn't know what gear you are in, so I'd focus on the cable adjustment/range switch.
Old Aug 11, 2024 | 10:04 PM
  #118
TrojanFan's Avatar
I'll keep you posted
Old Aug 11, 2024 | 10:38 PM
  #119
nomad2020's Avatar
Wow lots of issues on this car , looks to me that someone had either had tranny or engine off, from one of the videos i saw the torque convertor was spinning but not the flex plate and yeah bolts that attach one to the other were missing , on the shift issue sounds like shifter cable is out of adjustment, on the brake squeaking issue did you install ceramic pads or cheaper metallic /semi metallic pads? did you clean and lube the pins make sure calipers slide freely ? Oh and lastly not sure if you use the same auto place still but if it took them that long to figure out why engine was not turning( bolts missing at flex plate ) you need to get away from there asap
Old Aug 12, 2024 | 03:23 AM
  #120
TrojanFan's Avatar
I'm using ceramic pads
Yes I agree with you. I took it to the dealership thinking they would be able to help I've gotten way more help here then anywhere I could have taken it to. I'm glad you all are here!
Michael Williamson
Oct 15, 2017 10:37 AM
Frank_Jr
Aug 18, 2016 03:23 PM
trucknut88
Dec 12, 2012 05:07 AM
dwhitledge
Jul 24, 2012 05:25 PM
Absinthe
Jan 27, 2012 12:21 PM
