Do I need to use Honda Bond with a PermaDry Oil Pan Gasket
Old Oct 6, 2007 | 05:11 PM
ddavisso
Default Do I need to use Honda Bond with a PermaDry Oil Pan Gasket
I am replacing the Oil Pan Gasket on my 1996 Honda Accord LX 4dr Sedan (F22B2). I have read the various postings which state to use the Honda Bond (Sparingly). The Gasket that I purchased is a NAPA PermaDry. It states on the box not to use chemical adhesives. Should I return the NAPA Gasket and purchase the Honda OEM with the Honda Bond; use the Honda Bond on the PermaDry gasket or just use the PermaDry gasket as is? Thanks
Old Oct 6, 2007 | 08:12 PM
deserthonda's Avatar
Default RE: Do I need to use Honda Bond with a PermaDry Oil Pan Gasket
I have never used the permadry gasket so i could not advice you properly ,, but for as cheap as a Honda factory gasket is ( $ 25) i would use it , I know that it is going to fit correctly ,, also instead of Honda bond you ca use Ultra Flange sealer ,, it is basically the same as Honda bond but cheaper ..and as the post states just use a bit of it on the small sides ( the flat and the round ) only, on both sides of the gasket , nothing on the long sides ..
ccookie66
Apr 12, 2019 04:43 PM
frost506
Jan 16, 2012 07:21 PM
cruszczyk
Nov 14, 2011 08:06 AM
ufosearch
Feb 25, 2009 11:28 AM
MALSR
Sep 19, 2006 04:24 AM
