Does this look like a bad MFR? (Pic)
Old Aug 17, 2011 | 12:56 PM
HJCartman's Avatar
Default Does this look like a bad MFR? (Pic)
I was wondering if i could get some advice on the MFR. Maybe you guys see something i dont.
Old Aug 17, 2011 | 02:17 PM
Search viIZ8k60awY on YouTube. This is a video on main relay repair. It will also show you what a bad solder joint looks like. I can't tell if you have a cracked solder joint from your pic.
Old Aug 17, 2011 | 03:42 PM
HJCartman's Avatar
pahonda thanks again for the advice. I have been driving the car and it has not shut off on me. What its doing now is stuttering when i push the pedal. I also took the car to autozone and they checked the engine light and said it was the egr valve so i cleaned it but still does the same thing.
Old Aug 17, 2011 | 04:44 PM
There are a couple of EGR codes. You may have to clean out the port on the lower part of the intake manifold.
You would have to remove the upper part of the manifold to access.
joemoua
Jan 22, 2009 08:52 AM
ally
Nov 5, 2008 05:27 PM
marrymemercedes
Jul 2, 2008 11:54 PM
dvanvught
May 19, 2007 06:14 PM
ouchevelles
May 7, 2007 03:42 AM
