The dreaded no heat question.
Old Feb 21, 2018 | 01:06 PM
Seanjordan20's Avatar
I would think that the climate control is bad.
Old Feb 21, 2018 | 03:39 PM
Originally Posted by Wmertz63
Listing two motors could have went? Just seems odd they both went at same time.
And with the cost of that. I would prefer to be sure before spending money..
- What steps can I take next given the codes I received
thanks
Do you have a multimeter for testing?
Old Feb 21, 2018 | 03:43 PM
Wmertz63's Avatar
Yes but don’t know where to start
Old Feb 21, 2018 | 04:01 PM
If I have some time later today, I’ll try to put together something.
Old Feb 21, 2018 | 04:07 PM
Wmertz63's Avatar
Hey man appreciate it. No rush. Just the cold ride in the mornings lol. Luckily we had a heat wave here in Pennsylvania,
Old Feb 21, 2018 | 07:51 PM
Since you have several HVAC climate control trouble codes, let's try to rule out the two motors. You can unplug the green connectors to the respective motors, and apply direct power (+) and ground (-) to the respective motor terminal pins to see if they operate properly.
Both have green 7P connectors. If they do operate properly, then the cause may possibly be the Climate Control Unit or a short in the climate control harness wiring.
Accessing the connector to the Climate Control Unit is more time consuming; so, start with the motors.
Attached Thumbnails The dreaded no heat question.-air-mix-control-motor.jpg   The dreaded no heat question.-air-mix-control-motor-test.jpg   The dreaded no heat question.-mode-control-motor.jpg   The dreaded no heat question.-505781d1509829271-how-test-mode-control-motor-mode-control-motor-test.jpg
Old Feb 21, 2018 | 08:35 PM
  #17
I don't think it is the connector. The climate controls are known to go out at this age. My friend had the same issue 2 years ago with the a/c and the shop kept saying it was something else. I had him go to the junk yard to get a unit, put it in and the issue was resolved.
Old Feb 22, 2018 | 08:01 AM
  #18
Wmertz63's Avatar
Thank you!
- I’ll post results tomorrow
Old Feb 22, 2018 | 01:30 PM
  #19
Seanjorda20 - I agree the climate control is likely. Ruling out other possibilities like the motors using a simple test is a good step to ensure Wmertz63 does not waste money on a part that is working properly.
Old Feb 22, 2018 | 02:56 PM
  #20
I do agree. One side could of went out and he not notice then the other.
May 27, 2019 01:20 PM
c4yourself2
Dec 25, 2017 08:43 AM
jpilk99
Jan 2, 2015 11:26 AM
cuda6pak
Oct 5, 2013 09:38 AM
corvetteking
Jun 26, 2010 12:26 AM
