Early half 93 accord clutch w/pressure down but wont start
Old Feb 8, 2013 | 01:43 PM
stjohn31573's Avatar
Default Early half 93 accord clutch w/pressure down but wont start
My 93 accord wont even try to crank with the clutch in/down. Had starter and ignition changed in January along with a new battery. The dash lights up, it makes all of its clicks but when I turn the key nothing. I tried FAQing the problem in your archived threads but no one seemed to have this exact problem. Any ideas?
Old Feb 8, 2013 | 05:37 PM
Are you getting power to the starter soleinoid when you turn the key?
Also know there is a switch on the clutch pedal (two if you have cruise). If the "pad" that closes the switch on the pedal broke...replace it.
Old Feb 8, 2013 | 06:17 PM
SLIPKANOT's Avatar
Ya what he said. That switch should be inspected. there could be a number of things wrong with it. It might need to be replaced. Just grab a flash light and get down there and look around and see if you can cycle the switch on the clutch pedal a few times
jtimc7
Jan 29, 2013 04:31 PM
choyness
Jun 29, 2012 08:31 PM
turbo accord wagon
Aug 28, 2010 07:24 PM
rpowers2002
Feb 21, 2010 08:16 AM
superballz00
Nov 13, 2007 09:53 AM
