ECU Reset
Old May 24, 2012 | 07:14 PM
loungewire's Avatar
Default ECU Reset
Hello, Im new to the forums. Id been doing some research, but still havent figured it out. I know they are two ways: removing the battery negative cable or removing the ecu fuse. I actually want to reset my ecu from my car by removing the fuse. Just one problem, I'm having trouble deciding which one is the correct fuse I need to take out in order to reset ECU. Help ?
Specifics: I have a 2001 Honda Accord lx Auto transmission 4 cylinder.
Thanks in advance
Old May 24, 2012 | 07:45 PM
In earlier models (94-97) the BackUp fuse (7.5A) in underhood fuse box resets ECU. If you can't find that fuse, try looking on Autozone for online fuse box diagram.
Old May 24, 2012 | 09:36 PM
loungewire's Avatar
TexasHonda for you reply.
Apparently I don't have any (7.5A) in under-hood fuse box.
On the driver's side and passenger side I do indeed have alot of (7.5A) fuses.
Is there a chance for my car model, the fuse I'm looking is one of these two sides ? If anyone has info that can help me, please go ahead.
Old May 24, 2012 | 09:41 PM
Dr. Drivability's Avatar
Turn the ignition switch OFF, and remove the No.13 CLOCK BACKUP fuse (7.5 A ) (A) from the passenger's under-dash fuse/relay box (B) for 10 seconds
Old May 25, 2012 | 09:56 AM
Yes, 1998-2002 it's fuse #13 in the right-side-dashboard fusebox (near the right-front door hinges).
Old May 26, 2012 | 04:53 PM
loungewire's Avatar
It is indeed #13 fuse Clock/Back up on the Passenger side fuse box.
Thank You, it worked and everything went according to plan. Once again, thanks
Old Feb 2, 2013 | 08:21 PM
MrHollow45's Avatar
Default Ecu
Can any of you guys tell me where can I find the rest or fuse on my 99 Accord
Old Feb 2, 2013 | 08:29 PM
See post #5 in this thread:
https://www.hondaaccordforum.com/for...59-code-52497/
Old Feb 2, 2013 | 08:48 PM
MrHollow45's Avatar
Thanks redbull
Old Jun 21, 2022 | 05:32 PM
wowum's Avatar
Thumbs up Still working
Just a quick thanks. I just did this and it worked. My care is a 2001 Honda Accord 4-door, 4cyl engine, LX. 280K miles. It's been off road for a very long time ( 7 years?).
I just reregistered it and restarted it. It was running with a hesitation, jittering intermittently. Another post said it was the ECU that needed a reset if I had let the battery go flat. I had. But, that other post made incorrect (for my model) references to the fuse box.
You're post here matched the fuse boxes this car has. There is another fuse in the under-dash fuse box on the driver side labeled for the ECU but I did NOT remove that fuse. I only removed the clock fuse in the under-dash fuse box on the passenger side as you instructed. I took it for a ten minute test drive up and down some serious hills and it ran with no hesitation.
Thanks again.
Honda_Dude
Nov 5, 2007 05:28 PM
punyeta
Aug 29, 2006 02:40 AM
Zambo
Aug 13, 2006 02:40 AM
darryltravis
Apr 25, 2006 09:23 PM
HondaLawgik
Apr 16, 2006 04:19 AM
