Sponsored by:
Sponsored by:
electrical problem????
Old 10-29-2009, 06:05 PM
trukid21's Avatar
Default electrical problem???? (not the starting issue)
driving normally this afternoon, suddenly my ABS light came on then off,i hear a clicking noise by my glove compartment area and my radio would turn off then on,so does my radar and my speedometer/tachometer would shutdown then come back on(all at the same time). the car does not stall but this would go on till i turn the car off. but then, it would start back again with no problem, then i drive for a few blocks and it would start the same issue again. any thoughts on why its doing that?? early last year it did the same thing(somewhat similar) but i found out that my battery cable was loose.not today though,everything was tight and i'm not sure what to look for. thanks
Last edited by trukid21; 10-29-2009 at 11:08 PM. Reason: different issue(electrically)
Old 11-02-2009, 08:03 AM
Check the OTHER ends of the battery cables for corrosion/loose/dirt or something like that.
Also, check & see if you can make this happen by wiggling the key.
Old 11-03-2009, 08:21 PM
trukid21's Avatar
thanks jim, i cleaned up the battery ends and the post just to be sure and also added fluid to my brake reservoir(really low...TOTALLY FORGOT ABOUT THAT ONE) and now its good again. funny how that works huh?! thanks again.
calenatar
03-10-2006 03:23 PM
eddyfurukawa
02-13-2006 03:15 PM
qbtarget
02-13-2006 01:56 PM
dude9571
02-11-2006 12:17 AM
Mydnght2u
01-17-2006 07:18 PM
Quick Reply: electrical problem????
