Familiar Story: Crankshaft Pulley Bolt
Old Jul 6, 2012 | 09:15 AM
  #31
ctgriffi's Avatar
Originally Posted by Roader
If it fits then it's a better design. The one in the pic - and the one on my F23 - interferes a bit with the lower cover in that the lower cover doesn't sit flat over the installed retainer.
This retainer does fit, and it's very easy to install. I also installed the new OEM seal on the crankshaft; it's got a metal plate built into the back of it and is far more heavy-duty than the seal I had installed previously.
Soon, I'll get the belts back on and crank it to check for leaks. Stay tuned...
Old Jul 7, 2012 | 04:30 PM
  #32
ctgriffi's Avatar
Good news...after a long, hot morning, the car's done and running fine—no leaks!
I did end up putting the timing/balancer belts on and running it with the timing covers off and no alt or ps belts, so I could easily check for any leaks. At first it didn't want to start like this, so I hooked up both of the alternator connections and tried again. Started right up. I ran it like this (off the battery alone) for several minutes and never saw a drop of oil appear.
Final word: The Honda OEM crankshaft seal is far superior to the other available options out there, based on parts that I've seen online and at local auto stores; the fit is much snugger and the construction is much more substantial. Wish I'd never used anything else when I did the t-belt the first time around.
Thanks again to everyone that offered a helping hand. Much appreciated!
Old Jul 7, 2012 | 05:23 PM
  #33
Thanks for posting final outcome. Too often posters forget this and we are left to wonder.
Old Jul 7, 2012 | 05:27 PM
  #34
Thanks for coming back to let us know how things went.
Old Jul 8, 2012 | 06:59 AM
  #35
Yes, thanks for coming back..... good job of getting it done
rugrat
Jun 8, 2013 10:08 PM
Staged206K
Jun 8, 2013 04:44 PM
lvs4rock
Oct 25, 2008 04:31 PM
DeVoe41
Mar 24, 2008 08:05 AM
accordfan222
Oct 14, 2007 07:19 AM
