Fob won't shut off alarm on 95 accord
Old May 24, 2013 | 08:34 PM
Trevor Schmidt's Avatar
Default Fob won't shut off alarm on 95 accord
My fob completely stopped working and now I can't start my car because the alarm goes off.
If I unlock the car manually with the key, the alarm goes off and the engine won't start if the alarm goes off. It's basically stuck and un-drivable. I got a new battery for the fob but it still doesn't work. The fob is from the manufacturer. Any ideas on how to get my car started?
Old May 24, 2013 | 09:02 PM
From the manufacturer? You sure? I wasn't aware any 95s came with a fob from the factory.
Old May 24, 2013 | 09:03 PM
The alarm is not installed at the factory, so the dealer probably installed it. Take a look under the driver's side dash for wires that are not neatly organized and trace them to a box. That is likely the alarm control unit that you may be able to reset.
You may want to charge your car's battery, or test the battery voltage. A change in voltage could cause problems with the alarm. Hooking up jumper cables with another vehicle is another option.
Old May 25, 2013 | 12:23 PM
Actually the 5 door (wagons) EX came with a factory system - http://www.tegger.com/hondafaq/misc/98-011.pdf
As stated by PA - look for a reset....stange button by the hood release by chance?
lecompte51
Jul 3, 2013 01:38 AM
Zeerocks
Apr 19, 2013 12:26 PM
tomd
Mar 9, 2013 06:35 PM
mmckinney11
Dec 18, 2012 11:24 AM
christo16
Oct 4, 2009 10:26 AM
