head light replacement??
Hi total noob here.
My headlight (passenger side) went out on my 2002 Accord today on the way to work. I need to replace it in the parking lot before it gets dark. Can someone tell me how its done. Some of the newer cars are tricky. I'm hoping its super easy because its also raining. I tried the search function with no results.
Thanks!
Thanks!
6th gen Accords (1998-2002) use a 9006/HB4 bulb for the low beams. All you do it unclip the connector and twist out the old bulb. Then twist in the new bulb, careful not to touch the glass and reconnect the connector. Flip the switch and it should work!
82009_honda
Nov 26, 2009 09:17 AM
rtmobile96
Sep 27, 2007 03:30 AM
