Help! my A/c is all messed up
Old Oct 1, 2011 | 06:33 PM
JJ2003accordLX's Avatar
Default Help! my A/c is all messed up
I need some advice...my a/c when turned on only blows hot air. Not like heater hot air but like hot air from the engine area...not cold at all...I know I need refrigerant but also see that the compressor is not switching on even when hooked up to an a/c machine. I checked my neg cable comming from my battery but its grounded to the inside edge of my hood area...is this right? seems like it would need a more solid part to ground to, and could this be causing my problem? There is no voltage going to the compressor. please help its hot out here and no a/c sucks!!!
Old Oct 1, 2011 | 07:43 PM
What year, model, etc... accord are you working on?
Old Oct 1, 2011 | 09:10 PM
I assume this is a 2003 Accord LX based on your username?
When you turn the A/C on, if the fans under the hood are running, and the inside blower motor is running; but, the compressor clutch is not turning, then you may have a faulty field coil. Your symptoms sounds like the field coil.
Here's some info. to give some idea about the field coil (stator set). The link is for an Acura TL; however, it is somewhat similar. The attached image should be the part for your car.
"http://tl.acurazine.com/forums/showthread.php?t=772614"
This other link is for self-diagnostic of the A/C; however, keep in mind sometimes the code does not necessarily pinpoint the problem. Your symptoms sound a lot like a faulty field coil.
"http://www.driveaccord.net/forums/showthread.php?t=6778"
Copy and paste links without quotation marks (" ") to view links.
Attached Thumbnails Help! my A/c is all messed up-stator-set.jpg
97slowhonda
Oct 6, 2011 02:27 PM
MROOKIAN
Jul 23, 2010 11:30 AM
jmtdaddy
Oct 20, 2009 06:00 PM
dirkfisher
Apr 12, 2009 07:53 PM
YeuEmMaiMai
Sep 21, 2006 12:55 AM
