HELP!!!! Transmission problems
Old Sep 18, 2012 | 07:49 PM
  #21
Is this video taken after pulling the 7.5 amp backup/radio fuse? If yes, recheck for codes. Also check that 7.5 amp fuse is good. Check the ECU fuse (may be called PCM) it is 10 amp.
Did you check the grounds? The one on the driver's side of the upper intake manifold is an important ground.
How did you test the IAT sensor?
Old Sep 19, 2012 | 06:05 AM
  #22
Time_Will_Tell's Avatar
yes I made this video after I removed the 7 .5 amp fuse, had the car scanned at Autozone and it was just a 02 censor, I just visually inspected the I AT sensor, make sure all the connections were good, and reset the computer...
it's been about 200 miles, and the only thing throwing a code is the O 2 sensor.
I do I have downloaded a shop manual for my car, very detailed about 1300 pages...
and I'm using that as a reference and yes I have checked all my grounds...
mamtsberg
Mar 17, 2010 09:15 PM
pakman420
Mar 4, 2010 04:31 PM
WeeAsp
Jul 13, 2007 05:29 PM
kaotiklivin4eva
Dec 18, 2006 03:48 PM
KimberlyC
Apr 16, 2006 11:51 AM
