Honda fuel system problems
Old Sep 17, 2010 | 01:10 PM
45below's Avatar
Default Honda fuel system problems
Hey guys
Basically, my 1991 Accord LX overheated and quit on me. Not sure why it overheated... but I tried to start it yesterday to find out and it wouldn't start. It would turn over, just not fire.
I'm pretty sure the fuel pump is working... (When I turn on the car, the yellow light comes on on my dash and I hear a "whirring" sound for a couple seconds) But I'm not getting any fuel to my fuel rail. I don't think I am out of gas... my gauge still shows 1/4 tank... could it possibly be the ECM? I don't know much about the Honda fuel system.. any help will be appreciated.
Could this and the overheating problem be related?
Thank you. I really appreciate it.
Old Sep 17, 2010 | 01:22 PM
How did you verify that you have no fuel to the rail?
Old Sep 17, 2010 | 02:26 PM
45below's Avatar
I took off the fuel line on the left (passenger) side of the rail.
Old Sep 17, 2010 | 03:22 PM
Overheating should not cause your fuel problem, so you may be dealing with two different problems. How hot did the engine get? Check that the radiator is full of coolant by removing the radiator cap when the engine is cold.
I would add a gallon of gas so you can rule out an inaccurate fuel gauge.
Since you hear the fuel pump prime, that would indicate the main fuel relay (MFR) is working. You can do the same test with the fuel line removed and jump the connector for the MFR just to be thorough.
bartcv63
Jun 25, 2014 06:33 PM
woody
Sep 15, 2010 09:20 AM
i3igmind
Mar 6, 2010 09:08 PM
KimberlyC
Apr 16, 2006 11:51 AM
rogersah
Mar 22, 2005 02:56 AM
