Sponsored by:
Sponsored by:
How do you flush out the coolant in this thing?
Old 11-07-2013, 12:08 PM
93Accord2.2's Avatar
Default How do you flush out the coolant in this thing?
If it is all aluminum and I'm not supposed to put tap water in it, how do I flush it all out? I don't have air right now.. Will it like regular green coolant?
Thanks
Old 11-07-2013, 01:00 PM
Here's what I usually do...
- Turn temperature dial all the way to HOT so heater core can drain/fill.
- Remove thermostat so it flows right through - bolt-up housing without gasket.
- Flush with garden hose in & out every which way.
- Fill with garden hose, run engine for 40-50 seconds to circulate.
- Drain & look at the color in the pan. Repeat fill/drain until it's sorta clear.
- Fill/drain with distilled water maybe 2 or 3 times - should be pretty clear.
- Install thermostat with gasket.
- Add antifreeze (1/2 of total volume per spec usually is about 0.8 gallons)
- Top up with distilled water; you'll notice it takes a lot less because of water hanging out from last drain.
Normal green Prestone is silicate-free these days, but read the label. It's hybrid-OAT which I've been told is sorta more tolerant of minerals in tap-water anyway.
The amount of water that cannot drain is the reason I don't like to use pre-mixed 50/50 antifreeze.
Old 11-07-2013, 11:33 PM
UhOh's Avatar
^^^ Best procedure, and why do it this way discussion, I've read -
sgull
10-25-2014 05:40 AM
riverman
03-27-2010 07:41 PM
honda97acc
02-28-2010 08:29 PM
dtcaccord
06-04-2008 09:54 PM
wayneboard2
12-08-2006 11:56 PM
Quick Reply: How do you flush out the coolant in this thing?
