HVAC/Radio/Clock Upper display problem
Old Mar 26, 2009 | 08:59 AM
mellospace
Default HVAC/Radio/Clock Upper display problem
Hi all,
I have a '05 accord ex v6 Navi and I have a question about the upper display, the one for the radio/hvac/clock on top of the navi. When I turn on the AC, the temperature shown on the display start flashing/blinking and don't stop, the temperature is blinking as long as the AC is on. I would like to know if there is a problem with the display or is this the way it is or is there a way to fix that. I saw others online, but it seems like it just shows the temperature with no flashing/blinking like mine. There is no other problem with the display, everything else works as it should, except that.
I have uploaded a video so you guys can see what I'm asking about. The video is here http://tinypic.com/player.php?v=2ex59fn&s=5, there you can see the a/c temperature blinking when I turn on the A/C. Is this supposed to be like this?
Thanks in advance for any help with this.
Old Mar 26, 2009 | 07:07 PM
I would guess this may mean the ATC sytem has a fault. There are self-diagnositics for ATC systems. You will need to find out how to interrogate your ATC. I looked briefly, but couldn't locate anything. You may need a shop manual to run the problem to ground.
Old Mar 27, 2009 | 08:06 AM
mellospace
Ok thanks. I will see what I can find out about the diagnostic of the ATC system.
tkenwort99
Jul 10, 2012 12:13 PM
Robert"oh"
Jun 12, 2012 08:45 AM
shiggitty
Jul 11, 2011 11:29 PM
maroo
Nov 18, 2010 10:25 PM
robert_ansley
May 30, 2008 02:33 PM
