idle adjustment and ECU reset
Thank you to all for the invaluable info about my problem with the cluster dilemma. I have changed wires and plugs, cleaned the IAC valve and now the engine completely smooth....but the idle speed is about 700RPMS. The engine sounds like it is laboring. I understand that the idle may need adjustment. Do I also reset the ECU? What are the steps to setting the new idle speed and when do I disconnect the IAC....and when do I reset the ECU?
Darryl,, why don't you start by giving us the year and model,,,,,,,,and what do you mean the engine sounds like laboring..
idle at around 700-750 rpm is correct ,, you also say car runs smooth. so again what is laboring ??
