idle adjustment and ECU reset
Old Apr 25, 2006 | 06:34 AM
darryltravis's Avatar
Default idle adjustment and ECU reset
Thank you to all for the invaluable info about my problem with the cluster dilemma. I have changed wires and plugs, cleaned the IAC valve and now the engine completely smooth....but the idle speed is about 700RPMS. The engine sounds like it is laboring. I understand that the idle may need adjustment. Do I also reset the ECU? What are the steps to setting the new idle speed and when do I disconnect the IAC....and when do I reset the ECU?
Old Apr 25, 2006 | 12:20 PM
deserthonda's Avatar
Default RE: idle adjustment and ECU reset
Darryl,, why don't you start by giving us the year and model,,,,,,,,and what do you mean the engine sounds like laboring..
idle at around 700-750 rpm is correct ,, you also say car runs smooth. so again what is laboring ??
Old Apr 25, 2006 | 09:23 PM
Markus26's Avatar
Im interested in how you "cleaned" that IAC valve. thats the valve on the back of the intake manifold right?
toicy4ya
Aug 6, 2008 05:28 PM
Honda_Dude
Nov 5, 2007 05:28 PM
punyeta
Aug 29, 2006 02:40 AM
Zambo
Aug 13, 2006 02:40 AM
HondaLawgik
Apr 16, 2006 04:19 AM
