Idling When Cold
Old Mar 4, 2012 | 06:25 AM
When you replaced the rear, did you replace it with a vac controlled rear mount or a solid....I ask as some places offer both for the auto.
Anyway back to the idle. Strange you are getting different readings in P and D, the spec's I have say that it should be ~750 rpm's. I'd look into cleaning the IACV and give the tb a good cleaning as well. Then you might have to adjust the base idle.
When doing all the work, did you give it a tune up as well (cap, rotor, wires, plugs, ect)?
EDIT: Forgot, on the 4th gens there is the air boost valve as well, drivers side of the tb....early, need more coffee
Old Mar 4, 2012 | 10:14 AM
First90AccordMan's Avatar
I remember it being a vac controlled one.
When I replaced tps I cleaned throttle body, and when I was cleaning egr I said screw it and cleaned the whole intake. And yes I did th entire tune up wires plug cap etc. and I just set base idle when I was doing the tps.
Their is something that might do it, I did put in a aftermarket ect sensor. After I learned after market sensors and gaskets don't work. Had to learn the hard way.
Old Mar 4, 2012 | 10:41 AM
Please check the IACV and boost valve. Under load it should help in keeping the idle steady. P or D, you should have the same idle RPM's (~750). So you might need to reset the base idle again.
Old Mar 5, 2012 | 09:07 PM
Well I unplugged the booster valve and it did nothing at all, did not raise or lower idle, later I unplugged IACV and the car did not change idle at all, and then when I plugged it back in idle shot up to 1200ish. I reset ecu and now I'm back to square one. Also my idle screw is all the way down, I can't adjust it to go any lower.
Old Mar 6, 2012 | 06:41 PM
Check for vac leaks (intake gasket, vac hoses, PCV hose, ect).
d0n
Dec 10, 2014 07:42 AM
zedjr
Nov 1, 2012 05:03 AM
spoconn
Aug 21, 2009 07:06 AM
coupe_hybrid
May 31, 2006 10:11 PM
brokenspoke
May 23, 2006 04:11 AM
