lack of fuel pressure
just recently my car has lost a lot of power. i noticed that when i press the accelerator i hear a hissing sound, like a vacuum leak under the hood. i changed the fuel filter at first and when i removed the line from the fuel rail there was little fuel pressure. once it was changed it worked for a little while but when i got on the interstate the power was gone again. it hesitates at 2500 rpms. i was wondering if the fuel pressure regulator could be the problem? i seriously doubt its the pump because i can hear the vacuum leak but i cant find it even when standing over the engine. its like a whistling sound. any help would be well appreciated.
sorry i forgot to give specifics about my car. its a 97 accord ex 2.2 with a 5 speed. i just changed the one fuel filter by the firewall under the brake master cylinder. i didnt realize they have another one. anyways. i just noticed yesterday that the power comes back while im driving through town but goes away when i hit the interstate.
ORIGINAL: sir_nasty
No need to know the "color" we can still give advice.... Did you change the fuel filter at the carburator as well?
Dude was trying to make a point .. it is hard to give the correct reply without knowing the year and model,as it turned out you assumed car was carburated ..
that is why i stress the issue of putting year and model on the signature so all of us who are trying to help do not have to assume .
DElt there is only 1 fuel filter , the one that you replaced ,, since you did not input the year when you first asked the question , my main man SirNasty assumed that it was a carburated car which have 2 filters .
You should hook up a fuel pressure gauge , test drive the car at hwy speed and see where the pressurte is at
thanks desert honda, the problem i have about checking the fuel pressure is that on the 97 accord there is no fuel pressure service fitting like on the 94-96. so i dont know how to hook up a pressure gauge to it. ive looked online but havent found much help. my dad was gonna try and rig up a new hose with one but i wouldnt trust it myself. do you know of a good way to do it?
BigOBob
Jan 1, 2012 02:47 PM
iqoair
Aug 27, 2006 10:39 PM
