Leaking Trans
Old Sep 6, 2018 | 12:32 PM
dgp1961's Avatar
Almost A Senior Member
All - Just curious what are those two bolts and why doesn't anybody think the leak is coming from them?
Old Sep 6, 2018 | 05:23 PM
In your photo you can see 4 of the bolts that hold the transmission case together. There's more all around it & some are easily visible on top. They are relatively long bolts that extend to the split-line where the case comes apart. You can see them on the parts drawing at the first link I put in a few posts back.
The reason I think the leak is coming from up higher, is the side of the transmission is oily to much higher elevation than those bolts. Leaking oil drips downwards, and there's a handful of more likely things (up higher) that can be leaking.
Feel free to check those bolts for looseness, but don't OVER-tighten them. If they were loose, the oil would more likely leak from the gasket that's located where the transmission case comes apart. I wouldn't remove those bolts, because I think that'll create a new leak at that gasket.
Old Sep 7, 2018 | 12:15 PM
The Toecutter's Avatar
I agree 100% with what Jim said, as I saw the same thing. Gravity works very well, so it would be hard for the top to stay "wet" if the leak were at the bottom.
ruuruu
Aug 8, 2010 08:14 PM
sparlanc
Nov 22, 2008 08:36 AM
Illusive
Jul 30, 2006 02:10 PM
St3v3
May 14, 2006 04:05 AM
xbombtek
Jan 29, 2006 08:19 PM
