Loud Thump Under Braking
Old Jul 22, 2011 | 01:49 AM
douknowd22630's Avatar
Default Loud Thump Under Braking
I have a 95 accord ex coupe 5 spd that has a loud thump in the front end under braking, does it at slow speeds and faster ones also, but only under braking, I thought it was the front motor mount causing it as it was bad. I replaced it this evening and it still does it. Im just wondering if any of you have come across this and what it could be, I know its not the axles I just replaced both of them not that long ago with new axles not remaned ones. Any ideas would be helpful thanks guys
Old Jul 22, 2011 | 11:30 AM
draser's Avatar
I believe I read something about this on this forum even - you can try searching. But I believe it was the 99 MY and it was the rear mount - towards the cabin. Not sure if yours has one, but if it does do a visual inspection. Did you try to rock the engine by hand, also shift forward-reverse see if you hear noise?
Old Jul 22, 2011 | 12:58 PM
Thanks Ill check it, but the motor really doesnt move since we replaced the front mount, so any other ideas would be great
Old Jul 23, 2011 | 10:09 AM
I'd check the suspension parts for worn or missing bushings.
Old Jul 23, 2011 | 10:44 AM
Thanks Ive been researching it for the past couple of days and I think that I might be a bushing or something of the nature, hopefully I will find it and be able to fix it with no major issues
Old Jul 23, 2011 | 11:03 AM
Do any of you guys think that it could possibly be the radius rod bushing that are bad?
Old Jul 23, 2011 | 11:24 AM
Yes, that was the first on the came to mind when I read this but you should check all of them.
Old Jul 23, 2011 | 12:24 PM
Sethgreen's Avatar
check both control arms and the bushing that hold them, mine completely broke going over pot holes
Old Jul 23, 2011 | 01:38 PM
Well I will deff check all of them out while I have it up, thanks for the help guys, and Ill keep you posted to what I find
Old Jul 26, 2011 | 05:37 PM
So think that its the rear motor mount check all the bushings yesterday found no busted or worn bushings other than the sway bar end links which arent that big of a deal
97AccHondaMan
Oct 11, 2009 08:47 PM
Azrael
Feb 26, 2009 12:06 PM
ham00coupe
May 22, 2008 04:44 PM
lucky4babs
Apr 9, 2008 12:05 PM
xxxcoojaxxx
Jul 1, 2006 08:49 PM
