Manual Shift WONT Go Into Gear
Old Aug 13, 2013 | 02:37 AM
kramkram's Avatar
It is always going to build pressure the more you pump. I have always reversed bled the slaves when the normal way didn't work. Well kind of reversed. I used a turkey injector and take the needle off. Remove the slave or brake fluid cap depending on the car. put a piece of vacuum hose over the end then fill it with fluid, then open the slave valve up put the hose with the injector full of fluid on it and inject the fluid into it. This will force the bubbles out the top. You will be surprise how much quicker this is. Also forgot to add, between the fluid injections, do a normal peddle bleed to get any air that might of traveled to the inside pedal slave as well.
Old Apr 4, 2020 | 10:05 PM
Cee Jay's Avatar
Default My car
PROBLEM: Car will start once I step down on clutch, HOWEVER it will not let me drive 1st, 2nd, 3rd, 4th, 5th OR even Reverse.but it will go into gear just want move
Old Apr 5, 2020 | 07:57 AM
Seanjordan20's Avatar
What year model do you have? Was work done one the car recently?
I'm assuming it's not going into gear if it's not moving.
letsclique
Jun 18, 2016 04:29 PM
cukaracha
Jul 19, 2015 01:28 PM
d0n
Feb 4, 2013 08:45 AM
94LxAccordCoupe
Nov 4, 2011 07:38 AM
1999Accord
Oct 18, 2006 08:18 PM
