motor mount help???
Old May 3, 2010 | 08:31 PM
tyjoja's Avatar
Default motor mount help???
my son has an 88 accord lx auto he just purchased and we are fixing some items. I noticed when he shifts from drive to reverse that the engine lurches up a little and makes a little noise. Got out the haynes manual and jacked up the engine and it definitley moves up from the rear mount. The rear mount has a stud thru the mount from the cross member. when I jack it up both the stud and motor mount raise up. Does this sound right? you might think the stud would be part of the cross member and not move, but I'm not sure and can't tell. Does anyone have any knowledge on this. Are the mounts expensive? How hard is this to change? Fairly hard to reach but I may be able to do something with your help, and I appreciate all that in advance. Thanks bob
Old May 4, 2010 | 07:19 AM
I'm not sure if this drawing helps at all, but I don't have any actual experience with an '88. Which stud moves up?
ps. the picture includes more than one car, so I guess yours (automatic) would have #12 instead of #10 or #11.
Old May 4, 2010 | 09:36 AM
tyjoja's Avatar
Default thanks
It looks more like the part # 10 and has a stud sticking up through it. If you look down from behind the carb you can see the top of the stud coming thru the bracket. thanks bob
Old May 4, 2010 | 12:13 PM
Well, maybe I put the wrong information in the parts website, or maybe sometime in the last 22 years someone replaced the mount with the wrong kind?
Old May 4, 2010 | 06:12 PM
tyjoja's Avatar
Default motor mount
Thanks Jim, the schematic you provided may not be exact, but I looked the part up on several on line parts house's, and I can see my part on some of them, so maybe I'll see this weekend if I can get my old one off and try to match it up some where. Is it better to go with honda oem on this or is aftermarket ok. I'll look in the vendor directory also, thanks again, bob
Old May 4, 2010 | 06:42 PM
I would try to find OEM ones, because I have read about poor quality aftermarket ones.
Old May 4, 2010 | 09:08 PM
My picture was from www dot hondaautomotiveparts dot com
also...
manhonda dot com
slhonda dot com
T.A.S. Honda - I forgot their URL but they're a sponsor so look in the classifieds section
hondapartsdeals dot com (not sure if that's exactly correct?)
Old May 5, 2010 | 05:58 PM
deserthonda's Avatar
I agree........a lot of the non factory mounts have a lot harder rubber, too stiff ,
you might experience worse vibration
thetangstr
Aug 28, 2012 11:26 AM
baer77
Feb 27, 2009 03:47 PM
trvlnut
Oct 30, 2006 02:16 AM
Yangster
Sep 5, 2006 08:28 PM
Markus26
May 17, 2006 09:28 PM
