Need Help with my 94' Accord EX...problems?
I haven't had a cable auto, so I'm not really sure the proper way to adjust it. Search, I'm pretty sure HondaDude or someone has posted the proper procedure.
You check for arcing just like I said. Let the car get absolutely cold, after dark in complete darkness. Open hood & turn off all the lights. Start it & look for sparks. Even a dull blue glow around the wires is NOT supposed to be there. That would indicate some of your spark is being lost - leaking thru the insulation of the plug wires.
Try spraying water with a windex bottle. That brings up the arcing more visible too.
ORIGINAL: JimBlake
ok ill do that when i get the chance.. and ill let you all know...
Not the cable from the shift lever.The cable I'm talking about is from the throttlebody down to the tranny. Its job is to help the tranny decide when to shift.
ORIGINAL: JimBlake
Well sir, to fix the leaking oil/water you'll probably have to take it to a shop or a friend.
I can't tell you exactly what seal is leaking, but you can put fluid through your car that helps stop small leaks. (Any auto parts store)
astrocreep1369
Jun 29, 2012 09:30 AM
PrettiBoiHonda
Mar 28, 2012 10:39 PM
