No electrical on 92 Accord.
Old May 27, 2013 | 02:48 PM
Andrew C's Avatar
Default No electrical on 92 Accord.
I was replacing my radiator today after a minor fender bender, when long story short there was a spark when it touched the frame, and now there is no electrical at all. I turn the key and I get nothing.
I'm guessing/hoping it just a fuse but can anyone give me more information on which fuse would have blown or what else the problem may be?
Thanks.
Andrew
Old May 28, 2013 | 07:49 PM
I'd start with checking the "large amp" fuses in the underhood fuse panel. These are the ones held in by two screws and have a clear - at least when new - plastic window on the top....if you can't see thru the "window" that well, use a volt meter or test light and verify voltage to ground on both sides of them touching the meter to the screw heads and the other end to body ground.
Old May 28, 2013 | 08:04 PM
You also need to find the short that caused this problem.
Failure of main fuse (80 or 100 A fuse) would suggest a short in battery lead or alternator B+ lead which precede smaller fuses of other components. IE, the small fuses should protect the larger fuses from shorting.
TRIGGA
Oct 19, 2007 01:57 PM
thomas rouw
Oct 21, 2006 02:09 AM
honsolo
May 19, 2006 03:18 PM
eddyfurukawa
Feb 13, 2006 03:15 PM
qbtarget
Feb 13, 2006 01:56 PM
