no start/spark 1994 accord ex v-tec
Old Jul 24, 2011 | 05:38 PM
jitterjuice's Avatar
Default no start/spark 1994 accord ex v-tec
Im having spark issues with the distributor, Ive got everything but spark. Ive swapped distributors, caps, rotor button, plug wires are new. The car ran for the initial breakin, it was down on power and had a miss I assumed was a vacuum leak thaThe leak has been fixed. I tried 3 different distributors and still no spark. I tried to pull trouble codes by jumping the wires under glove box and nothing, no blinking at all. Ive checked all the fuses in both fuse boxes and all checked out good. Any ideas on what to do next? Thanks
Old Jul 24, 2011 | 06:16 PM
Check that you have 12V to body ground on the blk/yel wire that goes to the distributor two pin connector.
You may want to check the inputs for the ignitor as well. There is a 94 shop manual that you can download that will give you specifics. Open the common diy threads on top of the gen tech help forum.
Old Jul 24, 2011 | 08:53 PM
Ok thanks I'll give it a try.
Old Jul 25, 2011 | 06:32 PM
Double check the main ground (G101). Should be on the drivers/left end of the tb.
Attached Thumbnails no start/spark 1994 accord ex v-tec-5th-gen-g101-location.jpg
Old Jul 27, 2011 | 10:43 AM
Thanks for the help, you both were right. body ground was off, and I had to swap ignitor as well.
Old Jul 27, 2011 | 07:55 PM
Thanks for the update and glad you got it going......
martinez289
Mar 1, 2013 06:33 AM
Ron@honda95
Jun 26, 2012 06:41 PM
covered
Sep 20, 2011 07:14 AM
Bilster
Sep 7, 2011 03:36 PM
SeanAccord
May 18, 2010 08:24 PM
