not starting
Sry guys but this is what happened first AC started acting then there was a chk engine light got it chk it said o2 sensor so got o2 changed then a week later car stated idling really bad and killing so went back to advance this time they said misfire on all 4 cylinders and camshaft position sensor got hm and car wouldn't start unless u give gas while starting and sounds really bad so changed plugs and sensors and it did not help ANY IDEAS PLEASE GUYS
We REALLY prefer to get the actual error code numbers. Just saying "O2 sensor" it can be something like 8 different error codes that can mean different things. The code numbers are in the form of P1234 - or whatever numbers they are.
So it's a 2004 4-cyl but is it California or 49-state car? Coupe or 4-door? Automatic or manual trans.?
A damaged or stretched chain will set the P0341 trouble code. Infrequent oil changes, etc. can cause the chain to wear quickly.
portdave
Oct 19, 2007 09:10 AM
