oil drain plug washer
Old Jun 24, 2006 | 02:20 AM
desi01
Default oil drain plug washer
This might be a dumb question, but... I am new to cars and I am changing the oil on my 97 accord for the first time by myself and I read that you have to replace the washer for the drain plug every time you change the oil. I was wondering is this just a normal washer that I can buy at a hardware store or something special and where would I be able to get these besides online? TIA
Old Jun 24, 2006 | 03:25 AM
mpanelli's Avatar
Default RE: oil drain plug washer
No the "crush washer" is not just a regular washer. Yes it should be changed at every oil change to prevents leaks. You get them from your local Honda dealer. I think they are about 30-50 cents each. I usually go and buy 12 at a time because I can't always get to the dealer when I need them.
If you have an A/T you may want to change the fluid in it as well, depending on when it was changed last. It is as easy as changing the oil. When you go to the dealer pick up a "crush washer for the transmission, they are different, and 3 quarts of ATF-Z1 and drain & fill the transmission as well.
Good luck on the project.
Old Jun 24, 2006 | 05:49 AM
deserthonda's Avatar
DEs first off WELCOME to HAF,,,,,,,,,
secondly , no questions asked here is a dumb question,
and last ...
ok for Mpanelli..providing you with the correct replies ............
ChappyBob
Oct 27, 2016 05:44 PM
alltime3rdwheel
Dec 31, 2012 10:46 AM
jon02accord
Mar 26, 2008 10:54 AM
natesriv
Oct 31, 2007 08:44 AM
inthedump
Jul 23, 2007 03:23 PM
